Thread: Hayward pump stopped
    Jun 2010
    Dayton, Ohio
    241
    I unplugged the pump last night and plugged it in this morning and it won't turn on. No response at all. I'm kind of freakin out. Any clue what is going on?
    AGP: 24' x 52" cartridge filter: 13,500 gallons. Taylor K-2006 test kit.
    Jun 2012
    western NY
    1,560
    Re: Hayward pump stopped
    Did you chech your circuit breaker and gfci reset button. Motors don't just go bad overnight. Could be a dead spot in the windings, but that is a long shot. Check the simple things first
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2010
    Dayton, Ohio
    241
    I am totally clueless. What is a reset button? The outlet that the pump is plugged Ito is running other things so it's not the breaker. I would hate to call a repairman if I'm just stupid.
    Jun 2010
    Dayton, Ohio
    241
    Figured it out. It was a bad switch. Phew.
    22,548
    Glad you got it figured out.
    Jun 2012
    western NY
    1,560
    Quote Originally Posted by passionsrlz
    The GFCI that the pump "should" be plugged into will have a reset button on it. If it tripped for some reason it is how they are reset. I am curious...if there is a switch, why are you unplugging it?
