Thread: Posting question for a friend
    Lastrites's Avatar
    Jul 2010
    Newark, DE
    26
    A friend of mine recently switched his inground pool over to (Salt Water) at the end of last season. The pool is a 19,500 gallon Sand filter/Salt set up. He has not purchased the (FAS-DPD) test kit as of yet and has to rely on his pool store for the water analysis. I would help but, I live too far away to run the tests for him. After switching over to his salt set up, he's had nothing but problems keeping his numbers/water in the correct zone thanks to his local pool store and has recently noticed a slight green tint to the water. The pool store keeps selling him shock and phosphate products without any improvements.
    FC=1
    PH=7.6
    TA=90
    CH=250
    CYA=10
    Salt=2900
    From these pool store readings he gave me I informed him that he needed to add 130 0z. of (stablizer/conditioner) to bring his CYA level up to 60 and his shock level needs to be at 24 ppm assuming he has algae. I don't have a clue unless I'm there to check the water for him.
    If anyone on here has similar issues with (Salt Water) set ups could you please help give him some hints on what to do.
    12,000 gallon 15'-30'AGP (Cartridge Filter) SPECK 1.5 hp (Pump) TAYLOR 2006 (Test Kit)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Posting question for a friend
    Forget that it's a SWG system.
    He needs to take CYA up to 30, then perform the shock process using bleach. Trying to use the SWG will just burn it out. Once he's done, the SWG can go back on. And then he can raise the CYA up to 60.
    Without the test kit, the shock process is going to be difficult, wasteful, and time consuming.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Strongly recommend he get his own test kit. I hope he's at least using liquid bleach when he's shocking. Is he actually following the shocking procedure from pool school, or is he just throwing a packet of "shock" and that's it. Ask him to read pool school. pool-school/
    Mar 2009
    Huntsville, AL
    156
    If I were your friend I would:
    1. Buy a good test kit http://tftestkits.net/Test-Kits-c4/
    2. For shocking purposes treat my pool as a chlorine pool and raise CYA to the 20-30 ppm range. Then shock using bleach per http://tftestkits.net/Test-Kits-c4/.
    3. When the pool is clear and has passed the overnight FC lost test http://www.troublefreepool.com/pool-...rnight_fc_test finish the conversion to the salt water chlorine generator and raise CYA to the 60-80 ppm range.
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Lastrites's Avatar
    Jul 2010
    Newark, DE
    26
    Thanks everyone! I'll be sure to let him read this post and thanks for the info on the CYA range.
