Results 1 to 11 of 11
Thread: FIRST TIME INTEX EASY SET 18 X 48 OWNER
    Jun 2012
    Hudson Ohio
    47
    First off...I love this forum.Actually, it can become quite addictive. We setup the pool yesterday and got it filled by the Pool water company.We went with the saltwater system. Added the salt last night ..waiting for the 24 hours for salt to disolve..then will start the saltwater system.
    Pool boy(Hubs) wants to know if the scimmer should be left in the pool all the time.(maintence manual makes no mention). Any other do's and don'ts for the saltwater startup and maintenance would be appreciated..Just waiting for the water to warm up.
    18 x 54 Sharkline Matrix pool. 7800 gallons.
    Pentair Optiflo 1 1/2 HP 2 speed pump
    Pentair Clean and Clear 150 Sq Ft cartridge filter
    Hayward H100ID Heater. Purchased all from Poolsupplyworld. TF-100 TEST KIT
    May 2012
    Sturgis, Michigan
    20
    Re: FIRST TIME INTEX EASY SET 18 X 48 OWNER
    It wont hurt to leave the skimmer in all the time I do. it catches anything that may be floating in the pool. Also make sure you stir the salt up so brush your pool sides and bottom to make sure it is all stirred up. I would also add some bleach to get your FC level up to start with. Post a complete set of test results and we can give you more recommendations from there. You are going to need to add stabilizer but we need to see your pool results as well. Congrats on the new pool!
    AG 18'X52" round Ultra frame Intex 8961 gallons with sand filter and SWG 1600 gph also have TF-100 Test kit
    Mar 2012
    Amarillo, Texas
    341
    I leave mine in all the time, but it depends on how much stuff is getting blown into your pool.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Jun 2012
    Hudson Ohio
    47
    order the TF-100 test kit Saturday. Kind of running blind with the test strips that came with the Intex pool.Hubs and I have been reading Pool School..Chemistry 201..and all relative items..
    This is where we are at. Have the salwater filtration pump(see signature).
    After one day pool had .5 chlorine....76 ph..and 0 alkalinity on test strip. We then added baking soda..Alkatinity measured 120..PH off the chart..strip is red..FC was .05
    Until the test kits gets here..are we Okay?
    steinholder's Avatar
    Mar 2012
    Wichita, KS
    81
    Be careful what you put in, it can throw things out of whack. Look at the bottom of the pool calculator to estimate the additional impact of adding certain items. Balance is the key. Enjoy your pool!
    22'x52" AG Ultra Frame Intex - 12,500 gal (47K liter)
    Manual Liquid Chlorine - 1HP 100# Hayward sand filter
    Lots of sun, trees, pollen & wind - 50ppm Borates
    4nd season grateful TFP fan
    Jun 2012
    Hudson Ohio
    47
    We used the pool calculator this morning. It suggested to add 32 0z of Muriatic acid(we have a 5600 gallon easy set Intex above ground pool and we put 32 oz of bleach(6 %)
    Jun 2012
    Hudson Ohio
    47
    Is it safe to go in the water with the addition of the acid and bleach( we will add nothing more until the TF-100 kit arrives
    Mar 2012
    Wichita, KS
    81
    You want to make sure you wait between applications of acid and bleach, and 32oz of 6% bleach should have only raised you to maybe 3ppm chlorine. It should be safe, but adding chemicals without testing and swimming is not advisable.
    Jun 2012
    Hudson Ohio
    47
    Thanks so much for your quick response!! We just brushed the pool..on a Staycation this week(really want to take a dip).Just retested with"The Strip"..PH is still reading off the charts(very high).We just want to be safe with this reading swimming in the pool.
    Mar 2012
    Wichita, KS
    81
    I am new myself, and I know how a quick response can help. I know it's bad to swim with low pH (burning eyes) but I am unsure about high pH, and off the charts worries me some too.
    What is your Chlorine reading?
    You will need to add some chlorine each evening, I have a little bigger pool than you do, and I add about 2 cups of 12.5% chlorine each evening, my CYA is about 40 and my target is about 5-6ppm. You will need to just worry about CL and pH until our test kit arrives.
    Please make time to read up on pool school.
    Jun 2012
    Hudson Ohio
    47
    Chlorine result is perfect with "The test strip"..It is just the PH reading that is High...We added Baking soda (from Walmart on Saturday)...Come on TF-100..I will be able to share more accurate readings..Going for a dip..I will let ya all know
