Results 1 to 7 of 7
Thread: New Problem - please help
    May 2012
    Bowling Green, KY
    38
    I have been going through the shocking process all week and nearing the end (I thought). I woke up the AM and heard a louder than normal sound coming from the pool equipment house. I checked the pressure of the filter and it was up to 12 (normally runs at 6). I backwashed it and the pressure dropped. However, when I turned filter back on, my water clouded up again. It was like cloudy water was being shot into the pool through the filter spouts. Anyone know whats going on? My water was almost crystal clear before this happened. I'm also curious about the loud noise. Thank you.
    30,000 gallon, IG, Vinyl, Sand Filter, Hayward Super Pump - 3450 RPM, 1.5 HP
    South Central Kentucky
    22,537
    Re: New Problem - please help
    Did you seat the multiport valve back in position good? Did the handle return to the normal position? It could be a bad spider gasket.
    May 2012
    Bowling Green, KY
    38
    Yes, I seated the valve in position good. The handle did return to normal position. Could it have been that I didn't backwash long enough?
    Mar 2012
    Amarillo, Texas
    341
    Did you rinse after you backwashed?
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    30,400
    ditto that thought!
    May 2012
    Bowling Green, KY
    38
    No I didn't rinse after backwashing! Lesson learned. Do you think that was the problem? If so, how long to clear it up again?
    Forgetting to rinse allowed some DE to get into the pool. It should settle to the bottom overnight and then you can vacuum it up.
