Thread: newby, water is freezing
    wolfy's Avatar
    May 2012
    Randleman, North Carolina
    33
    I put up a 15x42 above ground pool one week ago. Temps are low 80's day and 58 at night. Should have some 90 degree weather here next month in July. Water is still too cold. Will it warm up later or always be this cold?
    16x48 Intex Ultra frame pool with swg
    Sep 2009
    Greentown, IN
    914
    Re: newby, water is freezing
    I don't know your location, but if your pool is in a sunny place and the night time temps heat up, you will see the water temps come up too.
    You might invest in a solar cover to put on the pool. It helps during the day to keep the sun's uv rays from consuming your FC, and insulates the pool at night from the cooler temps.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    I concur on the pool cover. My water was a balmy 84 when I got back from my vacation and pulled the cover. Then we had some cooler weather and the cover was off, dropped waaaaay down. I find the wind is the biggest culprit. It makes the water evaporate faster. And evaporation cools the water.
