Thread: switched to swg
    May 2012
    Jackson/New Jersey
    43
    switched to swg
    I switched over to a swg about two weeks ago. Aquarite is at 40%. Here are my numbers;
    FC = 5.5
    CC = 0
    TC = 5.5
    TA = 80
    CYA = 90
    Calc = 130
    PH = 7.2
    Pool water looks great. Should I worry about raising my PH and any other numbers that I should be concerned about?
    Thanks for your time!
    Brian
    25,000 gallon, in-ground, vinyl liner
    Hayward S244T sand filter
    Hayward super-pump 1.5 Horse
    Hayward Aquarite SWG
    Pool construction 1999
    Re: switched to swg
    Your PH will come up on it's own. There is no point in adjusting it.
    Everything else looks fairly good. If you have a vinyl liner pool your CH is fine. But if you have fiberglass or plaster your CH level is too low. CYA is a little too high. CYA will come down slowly over the course of the season, and you can probably get by with CYA a little high, but you need to be extra careful not to get algae or there will be challenges.
    May 2012
    Jackson/New Jersey
    43
    Re: switched to swg
    Thanks for the reply!
    I have a vinyl liner. Should I take the CYA down a notch or two?
    Brian
    Re: switched to swg
    Replacing a little water to get CYA down to 80 would be good. It shouldn't take very much water replacement to go down that small amount.
