Thread: Leaf Bagger or Leaf Rake ?
    Sailinshuz's Avatar
    Jun 2012
    Cartersville, Georgia
    48
    I have debris to remove from the bottom of my green pool. I don't have a lot of free time, or energy. I am considering a leaf bagger to help get the job done better, faster. Does anyone have any experience using one? Does it work any better than a leaf rake? Is it a pain in the rear to use? I'm skeptical about this product ...
    Dave
    Cartersville, GA
    IG Vinyl | 36K gal | 60 gpm Sand Filter | 3/4 hp pump
    Re: Leaf Bagger or Leaf Rake ?
    I assume you are referring to these things:
    http://www.amazon.com/Swim-Time-NA316-L ... B000MOIX3A
    I have one and it works very well. At spring opening this year I had a fair amount of smallish tree seed/pods to clear up from the bottom. No way I could do that easily with a leaf rake. especially through the haze. The 'bagger' whipped those up in no time. Obviously the mesh is not small enough to retain fine stuff which gets blown up in a cloud, but that usually settles quickly for vacuuming.
    The only 'pain' really is having to hook up to a hose. Mine just came with a female hose connection, so I fitted a quick hose connect. When lifting the 'bagger' out of the pool you have to invert it so that the bag contents do not spill out, so you might get sprayed a little, unless you fit an inline stop-****. Best also not to fill the (string-draw) bag too much at a time as it might slip off the base under the weight when inverted.
    If it is the type that runs on little ball wheels you might also want to check that they are smooth. Mine had a few burrs that I rubbed down. Don't want to damage the liner.
    So, yes, if you don't want to spend the bucks on an automated gizmo, I think they are well worth it.
    "Inherited" Cornelius 18'x54" Round AGP (Steel walls), Hayward Pro Series 21" Sand Filter, ClubPro (Jacuzzi) 1HP single speed pump, Lumi-O Festiva steps, Toile-Soleil mesh leaf net/winter cover. That's about it.
    Sailinshuz's Avatar
    Jun 2012
    48
    Quote Originally Posted by WorBry
    Thank you for the feedback on this. I like the idea of a larger bag than my Polaris.
    Dave
    Cartersville, GA
