Thread: Suggestion how to clean DE Separator bag?
    Mar 2009
    Glendora, California
    169
    Seems the bag on my separator has become so clogged I can't even feel water coming back to the pool when using it. The instructions only state to rise it after use, which I do. Any suggestion on what to spray or soak it with/in to hopefully clean it up? I believe the bag is made of nylon.
    Thanks in adavnace!
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: Suggestion how to clean DE Separator bag?
    I have a Hayward DE filter that cleans up somewhat easily but sometimes I need to take it apart to clean it. Can you take yours apart or maybe run water through it in the opposite direction? Sorry I can't help much and it seems not many have this type of system seeing you've got no answers yet. Good luck.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Here are cartridge-cleaning instructions. I think that they will apply to your situation. You could contact the manufacturer to be sure.
    http://www.unicelfilters.com/retailers/ ... _users.asp
    Support the site
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I also have a separation tank. I used the instructions for cleaning a DE filter and it seemed to help. First I soaked the bag in a TSP solution, then gave it a soak in a 10/1 water/acid solution to remove any builtup scale. If yours is like mine, it has a wire stiffening ring around the top. To avoid corrosion I made sure that it wasn't in the acid.
    chiefwej
