Thread: New intellibrite led too big for niche
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    403
    Bumbed out.... Just tried to install a pentair intellibrite but not fitting. About 1-2" too big. Looking around i didn't realize there were different niche/light sizes.
    Is there any kind of adapter?
    My pool is about 30 years old, is my niche size going to be too small for most new led lights?
    Draining the pool 24" or so to cut into the concrete really isnt a viable solution now.
    Appreciate any advice....
    Kevin
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: New intellibrite led too big for niche
    Well, they don't make an adapter for a hole that's too small, unfortunately If you have any idea who the manufacturer of your niche is, that would help, or at least take some measurements so you know how big is too big. I imagine the LED lights can come in a variety of sizes depending on the manufacturer, but I've never really looked.
    Jun 2010
    Dripping Springs, TX
    125
    Would a spa light fit? And would it be bright enough?
    17K gallon IG freeform Pebble-Tec pool w/ raised spa/waterfall, Hayward 6020 DE filter, Tristar 1 HP circulation pump, Tristar 2.5 HP spa pump, Silencer 2hp blower, Aquarite SWG, Polaris 280 w/ booster pump, Hayward Universal H-Series 400K LPG heater, Ultrapure Ozonator 25, Aqualogic PS-8
    Oct 2009
    3,899
    A spa light might fit, I'm not sure. It probably wouldn't be as bright as you would like though...
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    403
    I have a swimquip light. I ended up getting a J&J screw in LED light, white only. It was less watts than the Intellibrite (only 40w vs. iirc 65w for the intellibrite).
    It was hard to plunk down about $280 for the led. But now I have it setup to come on at night for a couple hours, which means we get to see and enjoy our pool more.
