Thread: PLUMBING DISTANCE
    May 2012
    charlotte n.c
    28
    PLUMBING DISTANCE
    So like most men i want to trick out everything i touch.
    My goal is to have my pump and swg away from the pool.
    if i hard plumb the lines under ground how far can i get away from the pool? i would only need the line to be about six feet from the pool. of course with bends and such im sure it would added up to 8 feet in and 8 feet out.
    this is just a "pipe dream" at the moment becuase i only have the intex 1000 gph pump but lets just say im crazy enough to try it. what do you think the result would be.
    INTEX 14' X 4'
    1000 GPH PUMP
    SWG
    taylor K-2006 K-1766
    SKOOBA VAC
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: PLUMBING DISTANCE
    8 feet is nothing! Go for it.
