Thread: Cloudy water/ bad cartridge?
    Ok, I've been battling cloudy water for 2/3 weeks. Kids are about to declare mutiny
    All my test numbers have been good. I've held at least 15ppm (up to 20+) FC constantly .
    CYA = 40
    CC = 0
    PH =7.4
    TA = 100
    Passed OCLT.
    My question is could I possibly have a filter/cartridge problem.
    I have a 24' AGP with a 1 HP /2 HP pump. Waterway Pro Clean 125 Filter.
    The replacement cartridge is 817-0125P - 125 sf. The dimensions of the 817-0150P- 150 sf cartridge appear to be the same. Would it be better to get the 150? Thank you, Mike
    Re: Cloudy water/ bad cartridge?
    How has the filter pressure been behaving? Has there been any visible improvement in the water at all in the last few days?
    The cartridge could be torn, or the cloudiness could be made of particles that are so small they pass right through the filter.
    Around 11/12 psi on high, 4/5 psi on low. I bought the cartridge last year, and I don't think it has ever been as good as the original.
    I think I recall stuff coming out of return while vacuuming last year. It's been too cloudy to tell this year.
    22,549
    IIRC the 125 sqft and the 150 sqft cartridges will interchange. I'd go for the bigger cart if it was me.
