Thread: Jandy Lite 2 LG250 won't ignite/fire
    I have replaced the temperature control assmbly with temperature probe into the heat exchanger and the analog on/off switch and analog temp dial.
    The pilot lite is on and it fired/ignited once but now won't fire no matter what I place the temp dial on.
    Heater is 6 years old.
    20x40 vinyl pool
    8' circular 900 Gal spill over spa
    SWG
    1.95 Pump
    84 degrees
    Jun 2012
    western NY
    1,560
    Re: Jandy Lite 2 LG250 won't ignite/fire
    Is this a milivolt system?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    How did you determine that those parts needed to be replaced?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
