Thread: Pool return fittings?
    Aug 2010
    Charleston, South Carolina
    77
    I'm building my inground pool myself and I'm a little confused on the pool return fittings. I ran 2" lines in a loop around the pool. Then dropped down to 1.5" and stubbed them out into the pool. But now I don't know which type of return fitting I need. I ordered some Hayward 1.5" wall fittings but they have threads on the inside and outside. So, I'm assuming these won't work and I need some kind of Insider fitting....maybe with an eyeball?? I see they make some with 1" opening, 3/4" and 1/2". Which ones would be best for the wall returns.
    I also have three seperate returns in the floor of a tanning ledge for a fountain/bubbler effect. They will have about 4" of water over them. I don't think I want eyeballs for those do I? Any suggestions.
    16' x 36', 19,000 gallons, Shotcrete
    Pentair equipment, SWG
    Savi Melody lights
    Tired of building....ready to swim
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    Apr 2012
    Klein Tejas
    249
    Re: Pool return fittings?
    I'm looking forward to any response from a pool builder. I'm likely doing the plumbing on my own pool build and the selection of fittings and their descriptions online is daunting.
    Have you looked at Waterway's selection? They have pretty good pictures of their glue on returns.
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
    Aug 2010
    77
    yeah, I've looked at waterway's stuff. I even called them, but their tech guy barely spoke english and basically just looked at the catalog and picked a few fittings out.
    A standard plaster return wall fitting has a slip joint that gets glued to the pipe and a 1.5 inch interior threaded hole on the pool side. The outside has ridges, often much like threads, that engage the plaster to help hold it in place. The standard return eyeball fittings (amiable with a smaller hole) then screw into the 1.5 inch threaded hole.
    Vinly liner pool return fittings have true threads on the outside that are used with a plastic nut to screw it down to the pool wall.
