Results 1 to 8 of 8
Thread: Triton minmax400, troubleshooting
    Hello all, my heater, which is 10 years old, has been giving me problems. The spa switch has not been working,neverless, I have been using the pool switch to heat my spa. Well the stat was off last week after I opened up the pool. Now, I have only the power light on,no other lights(therm,aux,press,heat). I was thinking this could be a thermostat circuit board operation problem(which then means expensive circuit board replacement). I've had mice make nests,which i've cleaned up and heat shrinked some wires,that they chewed. After that, everything worked fine, until yesterday.
    29000 gallon inground pool with connecting spa,pentair DE filter, Titan minimax400 heater, Polaris 360 pool cleaner.
    May 2011
    Orange County, CA
    696
    Re: Triton minmax400, troubleshooting
    Sounds like a problem with the thermostat board. Is this a Minimax or Minimax CH? You can probably find the thermostat board online, but you need to know exactly which model. The swap out should be trivial. It's also possible that the rocker switch may need to be cleaned up with som DeOx spray. This helps to fix problems with switches and potentiometers. After a while, they build up oxidation products that interfere with conductivity. I'd first go with the DeOx route and then move on to purchasing a new thermostat board.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Thanks Craig for the quick response. My OM says minimax plus and powerMax, nameplate states miniMax 400. What is minimax CH? By DeOx do you mean WD-40? Or a specific electrical spray.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Quote Originally Posted by Bob d
    No not WD-40. DE-OX-ID Premium Electronic Contact Cleaner. You might have to buy it from eBay if not found in stores by you.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Thanks Paul, confirmed circuit board,ordered it; $85. Will do install when it arrives, looks like old board just snaps away from plastic friction fasteners. Took switch off and used electric contact cleaner,reinstalled.
    May 2011
    Orange County, CA
    696
    Bob:
    The MiniMax CH line is a newer one than the original Triton MiniMax. They appear to have slightly different parts. In any event, once the board comes, you might want to DeOx the crimp connectors that plug into the thermostat board, just to make sure there is good contact. Let us know how this turns out.
    Received and installed board, everythings working. Thanks for all the help, really think that the mouse peep was the culprit.
    May 2011
    Orange County, CA
    696
    Great to hear it worked out! Sometimes the fix is relatively simple.
    Cheers...
