Thread: Broken concrete holding coping
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    I guess with this portion of the cement moving, a weak spot has been exposed, also the metal clip holding the coping is rusted pretty bad, not sure how long this will last. The guy that installed our liner a few years ago said this would be the last time we can change the liner without doing some repair, and replacing the inner walls.
    He said it might cost 20k to redo all the concrete, coping and interior walls. It would probably be like buying a new pool, just they don't have to dig the hole or redo the bottom. Sound right?
    [attachment=2:1jp3k3d8]ImageUploadedByTapatalk1339163374.884606.jpg[/attachment:1jp3k3d8]
    [attachment=1:1jp3k3d8]ImageUploadedByTapatalk1339163410.326928.jpg[/attachment:1jp3k3d8]
    [attachment=0:1jp3k3d8]ImageUploadedByTapatalk1339163422.635746.jpg[/attachment:1jp3k3d8]
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Broken concrete holding coping
    While I'm not an expert on vinyl pools, that doesn't look horrible to me Hopefully someone with more experience will comment. 20k sounds excessive to me!
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    The metal that holds the coping is embedded in the concrete and the coping itself is in the concrete, which seems like a bad design since you can't change damaged copings.
    K-2006 Test kit
