Results 1 to 7 of 7
Thread: Pool Timer for twist lock plug with 1.5HP pump
    Jul 2011
    Lehigh Valley, PA
    163
    Hi guys. I have a 2 speed 1.5 HP pump. I have it pluuged in with a twist lock plug. I assume that means I have to have a twist lock timer ? Any idea of the best place to get one ? It seems the twist lock ones are double the price of the regular oness.
    21' All Steel AGP with Resin caps, Heyward S244T Sand Filter, Heyward 1HP 2 speed pump
    Re: Pool Timer for twist lock plug with 1.5HP pump
    The Intermatic P1131 is good up to 15 amps. If your motor needs more than 15 amps you may need to switch to a hardwired timer.
    Jul 2011
    Lehigh Valley, PA
    163
    Yeah I saw that one. I dont "think" my pump is rated highter than that. I have the Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed.
    It just bites that the twist lock timer is 25$ more than the regular standard plug timer. Do I HAVE to have the same type of plug as my pump ?
    22,551
    You can buy a hardwired timer and add a twistlock receptacle to it. But in the end it's probably going to cost as much as buying a TL timer. You could just cut the plug off and hardwire it.
    The twist lock requirement varies from place to place. In many areas you have to either hardwire or have twist lock. In other places a regular plug is acceptable.
    There should be a plate on your pump listing the peak Amps used.
    Jun 2008
    NJ
    12
    just saw this post.
    I ordered The Intermatic P1131 from amazon.
    I used it Aug of 2012 for one month then put it away.
    This year it lasted one week and it died.
    My pump is 1.5hp
    Not sure what else to try.
    5100 gal Above Ground Intex Pool with cheap filter and pump
    TF-100 Test Kit
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    If it's running on a 112 volt circuit it could be pulling at or close to 20amps with your 1.5hp motor. That timer is only rated for 20 amps max and a 1 horse motor.
    The timers specs: http://1000bulbs.com/product/3315/ELEC- ... opping.com
    Solar Blanket, Well Water, Borax Added. 68°
