Thread: Can I add the ph control option to my Autopilot?
    Round Rock, TX
    I purchased and install my AutoPilot Digi 200 last year. Is there a place where I can purchase the PH controller/ acid tack/pump portion to get the complete setup?
    My looking online only provides buying the whole thing at once.
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    The parts are available separately if you look hard enough, for example here, but the main unit in the Total Control system is not quite the same as the main unit of the Digital Model. Last I heard, the Digital unit won't interface with the chemistry controller, so there is no add-on upgrade path. You can use the manifold and cell with either system.
    Apr 2008
    SW Florida
    Sorry, but as of now you must have a 75003 controller to use the Total Control. Though it looks the same, they are two different units. Jasonlion is correct in that you can use the cell and manifold
    Apr 2008
    Burlington, WI
    My understanding is that you cannot update to the Total Control system. However, you can accomplish the same task by adding a CAT controller.
    You can check them out at CAT Controllers: Paul – office # 800-657-2287. You will receive a good synopsis from Paul.
    I have talked with him many times, he is very helpful.
    58,800 gal gunite INDOOR pool w/ spa
    automatic cover
    Jandy "stuff" - pumps, cartridge filter, aqua link
    CAT Controller 4000
    Stenner 30 gal (bleach) and 15 gal (acid)
    Puck chlorinator and Nature 2- gone
    Hi-Z Heater - natural gas
    Ft Lauderdale, Florida
    We also have the pleasure of having a new member on board, AndrewCAT, who works for CAT controls.
    Sean Assam -
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps
    AutoPilot Salt Chlorine Generators
