Thread: Not a great opening day.
    Just opened the pool today. Not looking good. I'm topping it off right now so I haven't done any testing yet. The main issue a lot of green hovering around the bottom. Is there a way to post a picture?
    I'm trying to decide how I want to tackle it. One thought is after the pool is filled, to vacum to waste, probably a couple times, before testing and balancing. Or, should I just test, balance then shock and keep backwashing.
    Thanks in advance for any ideas
    JimB
    on the Northcoast of the U.S.A.
    24ft AG-13,500 gal-Hayward S-166T high rate sand filter-pump is SplashPak Hp 1spl (whatever that means)-TF100 test kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Not a great opening day.
    You can use photobucket to host your pictures. The accounts are free and it is fairly simple to use.
    If you can vacuum to waste very slowly so you disturb the algae as little as possible you may be able to get things straightened out without having to filter out the debris for a week or more. Then you can test and get pH in line if needed, and after that begin the shock process.
    Love TFP? Become a
    TFP Supporter!
    That's kind of what I was thinking.
    I used to have a photobucket account. If I can find it or start another one...sorry to be a bit slow here, it's getting late...is there a help section here that says how to do post a picture.
    Another quick ? Does troublefreepool have an android app? I'd be willing to pay for that. I did find a pool care app called 'Pool Care' by Zac Lippard. I think it's for keeping track of test results and I think it calculates how much chemicals to add. Not sure if it goes by the bbb method
    JimB
    22,542
    The forum uses Tapatalk for the reading app.
    There's a guy on the forum that has developed an app for test readings. It's Simple Pool.
