Thread: Hayward SP3400VSP priming question
    Mar 2012
    Eastern Long Island,New York
    82
    When starting up it fails to prime when in auto detect.
    20 X 40 Vinyl IG 28K gallons, Heat Siphon Z700HP, Hayward 4820 DE, Hayward SP3400VSP, Jandy aquapure 1400, TFTest Kit, Pool School, Pool Calculator
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Hayward SP3400VSP priming question
    Well, I'd just leave it on the 3min prime Do you know why the system is losing prime when the pump is off? Ideally it wouldn't, and it means you have a leak somewhere (may or may not be significant). Do you have a bunch of air in the pump basket?
    As for the skimming speeds, that just depends on trial an error, since each pool is different (amount/type of debris, etc). I'd probably start by running it as low as the SWG will let you, and then bumping it up if the pool is getting too dirty.
