Results 1 to 14 of 14
Thread: High Chlorine
    Jun 2012
    Sims, NC
    21
    High Chlorine
    Hi, I'm a new pool owner. We went with a 24' round above ground salt water system. Every time I test the chlorine, it's showing off the charts. I ordered the TF-100 and did the test today and when I test the chlorine, it is showing orange instead of turning yellow. The SWG has been at 100% since we bought it, probably been a month and I didn't realize until I did a test that it was so high. I'm guessing I should just turn the SWG to off and let it run a few days like that to get it down? I ran it on 30% yesterday and half day today until I turned it off when the test kit arrived. Here are the other #'s I got:
    FC 1.85
    CC 0
    TC (just add those 2?) 1.85
    TA 90
    CH 250
    CYA 50
    Chlorine looks orange when testing
    ph seems around the 7.5 mark with TF-100 and 7.2 when I use the pill looking kit that came with the pool
    24' AG 13,000 gal
    sand filter
    SWG
    TF-100
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: High Chlorine
    Welcome to TFP!
    You can't measure 1.85 ppm FC with the TF-100. The normal test is 0.5ppm per drop, so maybe you got 18.5ppm from 37 drops?
    Jun 2012
    Sims, NC
    21
    Re: High Chlorine
    Yes. I believe that's right. Put decimal in wrong spot.
    24' AG 13,000 gal
    sand filter
    SWG
    TF-100
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: High Chlorine
    When you sat the test turned orange, I am assuming that you were using the T-1000 kit that has test vials for chlorine (OTO test which measures Total Chlorine) and ph attached to each other? If yes, then a FC or 18.5 ppm(as measured by the TF-100 FAS-DPD kit)would likely show up as orange on the OTO Total Chlorine test, though that test is really only accurate up to 5 ppm.
    Jun 2012
    Sims, NC
    21
    Re: High Chlorine
    That's the test kit I used. The T-1000 kit. Would turning the swg off and run it a couple days the best to do to lower it? Im hoping its still safe to swim in it? How's the other numbers look?
    24' AG 13,000 gal
    sand filter
    SWG
    TF-100
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: High Chlorine
    Shut off the SWG and leave the pool uncovered. Not sure where you are located but hopefully the sun will burn it off in a few days. It may take awhile seeing you have 50 CYA. You should monitor it closely so it doesn't drop too low but orange on the non-powder test kit is pretty high.
    Check out this link for recommended SWG numbers, you are really close on most. pool-school/water_balance_saltwater_generator
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Jun 2012
    Sims, NC
    21
    Re: High Chlorine
    I'm in Eastern NC.
    24' AG 13,000 gal
    sand filter
    SWG
    TF-100
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: High Chlorine
    Quote Originally Posted by Slickster
    I'm in Eastern NC.
    It should burn off quicker than it would up here.
    Mike
    Jun 2012
    Sims, NC
    21
    Re: High Chlorine
    Just tested again, dropped just a little bit, down to 18. Is it safe to swim? Kids are going nuts wanting to jump in.
    24' AG 13,000 gal
    sand filter
    SWG
    TF-100
    Mar 2010
    Spring, TX
    1,082
    Re: High Chlorine
    From my reading here, if the FC level is at or below shock level for your CYA level it is safe to swim.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: High Chlorine
    mynewpool is right on. CC>0.5, water clear, and FC at or below shock level (for your pools cya level).
    What I don't understand is why your FC is taking so long to come down. Am I reading that you only dropped 0.5 ppm FC in two days? Have you turned off the swg? No other chlorine sources going in? How much sun do you get on the pool?
    Jun 2012
    Sims, NC
    21
    Re: High Chlorine
    Yes, the SWG is off, yesterday was the first full day it was off. I had it on 30% for most of the day on Thursday until I tested it, then I turned it off. So basically one full day off not counting the 1/2 day today. The pool gets about 7-8 hours of direct sunlight before the shade starts to cover it. How do I know the shock level of my pool? I'm new to all this.
    24' AG 13,000 gal
    sand filter
    SWG
    TF-100
    Sep 2009
    Greentown, IN
    914
    Re: High Chlorine
    You can plug all of your information into the pool calculator, find it in pool school, and it will tell you at the bottom of the page what your shock levels are. The shock level for a pool is related to how much CYA you have.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: High Chlorine
    poolcalculator.com gives me a shock value of 16 ppm for your 50 ppm cya level.
