Results 1 to 11 of 11
Thread: Am I missing something?
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Ok...the last 2-3 weeks, the pool's been going through 4-5 ppm of chlorine a day. Never less than 3.5 (on no bather days), around 5 on high load days.
    Here's what i know and what I've done:
    1) I test in the mornings as a general rule, usually between 6-7am. CC will be .5 3-4 days a week, 0 the other days. Never, not once, has it ever been more than .5
    2) CYA is 50, has been the entire time, tested weekly at a minimum, double checked 2-3 other times. Wife has also performed the test, with the same assessment of the results...CYA of 50.
    3) Pool is always crystal clear, even on mornings after storms have blown a few leaves in.
    4) I've performed 3 OCLTs since I started noticing this high usage. FC losses of 0, .5, and 0
    5) The pool gets direct, unimpeded sunlight from sunrise until 30-45 minutes before sunset. There are no trees or buildings nearby enough to cast any shadows or shade until very late in the afternoon, and the shade never completely covers the pool.
    6) I've used 3 different brands of bleach during this time, each has been tested to confirm strength by testing FC 60-90 minutes after adding bleach, each time confirming FC was what would be expected for the given amount of bleach added, according to Pool Calculator.
    7) My target each morning is 7-8 FC (lately 8, knowing I could expect to lose 4+)
    I've got absolutely no indication that anything is using up chlorine...except for the fact chlorine is being used up. *heh* (Anyone remember A Few Good Men? Doctor, was there ANY sign of violence? You mean, aside from the dead body?)
    Is it reasonable, given the long days of direct sunlight, that the pool is simply using that much chlorine daily? If so, would a slightly higher (60-70) CYA level be appropriate? Or am I overlooking something that suggests the pool should be shocked?
    Thanks in advance for any assistance.
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    Re: Am I missing something?
    I don't see the problem or am I missing something? Pools consume chlorine. Your consumption looks perfectly reasonable to me.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Numerous statements around here suggest 2-3 is normal, 4 is "high", and 5+ is "excessive", even for lower CYA levels of 30-40.
    -Gordon
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    For example, note this thread:
    Jason says
    A typical pool uses about 2 ppm of chlorine per day, but that varies a fair bit depending on how much direct sunlight the pool gets.
    Am I really getting SO much 'direct sunlight" that my typical usage is 2.5 * normal?
    Allison says
    Mine is 3-4, but that is with Texas heat and not a bit of shade anywhere near the pool. I plan to slowly raise my CYA this year to see if that helps any (stills staying below 50).
    Even with a CYA obviously below mine, and "not a bit of shade", her usage...in a warmer environment...is 60-80% of mine.
    In this thread Dave says a 5.5ppm 1-day loss with 'a few swimmers" is "excessive".
    -Gordon
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Fair enough. Good info from Jason there. Thank you for digging that up
    Seems a bit contradictory, however, when the same loss was later considered "excessive" for a LOWER CYA level of 45.
    -Gordon
    I am by far, not an expert but my theory is....it takes what it takes.
    10,000 gallon
    NC KANSAS44
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Quote Originally Posted by Thinkly
    Fair enough, probably a pretty good theory.
    I guess it's just my OCD nature...after all, if I didn't want to know EXACTLY what was happening in my pool, I wouldn't be doing BBB to begin with, now would I?
    -Gordon
    I've noticed that mine has been using around 3.5/day when it's uncovered (direct sunlight from 10am-5pm).
    I'm guessing with normal use on a sunny day it could use up to 4ppm. Haven't had it uncovered/in use all day yet this year.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    solarboy's Avatar
    Aug 2010
    Europe
    337
    I lose crazy amounts this time of year due to wind blowing in pollen and other dried plants material into my pool, as well as very intense summer solstice levels of sunshine. We're close to the solar maximum at the moment.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    That's making a bit more sense then, since ours is probably in full sun from 8-6 or better, and uncovered 24/7.
    -Gordon
