Thread: COntrol Hayward Equipment with Pentair Easytouch Automation
    We are in the process of building a 15,000 gallon pool / spa with a heater, slide, waterfall, etc. Would like to get an auotmation system to simplify control of the system.
    With the Pentair Easytouch system is it possible to control a Hayward pump, filter, heater, etc? or does it have to be Pentair equipment?
    Your help is highly appreciated.
    Johan
    10,000 gallon inground fiberglass pool and spa, Pentair Variable Speed 3.0hp pump, Pentair 520 filter, Pentair MasterTemp 400,000 BTU Heater, Pentair Easytouch 8, Screenlogic Connect, Wireless Controller
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: COntrol Hayward Equipment with Pentair Easytouch Automat
    I'm pretty sure that they can. Unless someone else here comments first, a quick call to Pentair or Hayward should get you a solid answer.
    Pentair automation can control any single speed and two speed pumps and any kind of heater without any problems. If you have a Hayward variable speed pump there will be some minor limitations on what you can do and it will require extra relays in the automations system.
