Thread: Polaris Vac Sweep 280 Question
    Jul 2011
    Surf City, California
    24
    I am looking at purchasing the Polaris Vac Sweep 280 for my inground gunite pool. It indicates it needs a booster pump. When I had my pool built I had a independent suction line put in to hook up a Vac. Will this qualify as a booster pump? In order to turn on the suction line, there is a lever that stops the skimmer and diverts it to the suction line.
    Any reviews about the Polaris Vac Sweep 280?
    25-30K Gallon Inground Pool and Spa
    DE-Filter system 60 Sq. ft
    Salt Chlorine generator
    Pebble Bottom
    Variable Speed pump
    Feb 2012
    Phoenix, AZ
    728
    Re: Polaris Vac Sweep 280 Question
    The polaris 280 is a pressure side cleaner, which runs off a booster pump. The suction like you describe was actually made for a different type of cleaner - a suction side cleaner. So in short, no you cannot use your suction line to run the 280. You can either get a 280 and booster pump, or get a suction side cleaner that runs off your current plumbing.
    As for reviews, the 280 is a very popular cleaner. Finding reviews should not be difficult, either on this forum or google.
    Jul 2011
    24
    Thanks! Helped me clear up the question of the booster vs suction.
    Pebble Bottom
    Variable Speed pump
