Thread: Non-OEM Replacement Filters
    Jun 2011
    Ridgefield, CT
    73
    Is there a reason to get only OEM replacement cartridges? I purchased non-Jandy cartridges last year (manufactured by Pleatco). They seem to get "dirty" faster and result in quicker increases in psi. I found that my old Unicel cartridges could take a greater beating than the Pleatco ones while keeping the pressure in the preferred range. In addition, it seems like they did a slightly better job of catching the small junk that often goes through the filter and shoots back out the returns when I am running with the Pleatco cartridges. I have noticed that the Unicel cartridges feel more substantial. They are heavier. And the center is bi-sected, whereas the center of the Pleatco cartridges are completely hollow.
    33,000 gallon plaster pool
    Jandy L-Series -CL580 Cartridge Filter
    22,544
    Re: Non-OEM Replacement Filters
    There's nothing wrong using non-oem filters as long as you're satisfied with the performance. Different mfgs us different materials, different weaves & different manufacturing designs. Not saying they're bad, just different.
    mas985's Avatar
    Pleasanton, CA
    11,737
    This is second hand, but I have heard of reports that Pleatco sells inferior cartridges made of thinner material that don't last as long. However, Unicel & Filbur are viewed as equal to an OEM cartridge.
    Mark
