Thread: Chlorine usage?
    Chlorine usage?
    Folks,
    What is average chlroine use for pool with little swimmer activity?
    How can you make less chlorine work more efficiently?
    Thx,
    Tim
    I had to shock on sunday, added 2 three inch tablets, and added more today. Doesnt seem excessive but was curious of normal rate.
    Thx.
    38k, Pentair clear plus cartridge, Ig, pebbletec, 2hp pump w a .75 booster for a hayward phantom. 150gpm flow rate on the filter. Its a free form offset kidney shape with built in spa, swim out in the deep end with wide built in steps on the shallow side.
    Re: Chlorine usage?
    A typical pool uses about 2 ppm of chlorine per day, but that varies a fair bit depending on how much direct sunlight the pool gets.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Re: Chlorine usage?
    Mine is 3-4, but that is with Texas heat and not a bit of shade anywhere near the pool. I plan to slowly raise my CYA this year to see if that helps any (stills staying below 50).
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
