Thread: Is it OK to have pump filter below ground level
    I will be putting up an Intex 18'x48" Ultra Frame soon.
    I have a sunken cement patio the is roughly 3 feet below ground level.
    I have a 1HP Hayward Pump - 16" Sand Filter combo.
    I have an Intex SWG.
    I have a solar heater.
    The pool will be installed on level ground in the back yard about 6 feet from the sunken patio. I would like to put the pump/filter and SWG on the sunken patio (3 feet below ground level) and then plump a bypass for the solar heater at ground level after the SWG on the return path to the pool. So essentially I would have:
    (18'x48") Pool --> (3 ft. drop) Hayward 1HP Pump/SF --> SWG --> (3 ft. rise) Solar Heater w/Bypass --> Pool
    This would make the base of the pump/filter ~ 7ft below water level. Will this combination work with a 1HP/16"SF Hayward pump? I would really like to keep the pump and filter off of the grass and save some room for the solar heater.
    Any thoughts are greatly appreciated.
    Regards,
    Scott
    22,544
    Re: Is it OK to have pump filter below ground level
    That shouldn't be a problem at all. It'll increase your discharge head a little but it'll also decrease your suction head so it won't be a problem.
    Jun 2010
    Glendale, CA
    513
    This may not need to be said but - make sure there is a ball valve in the line from the pool. If you ever need to disconnect the pump for whatever reason that line will be pressurized by the elevation drop.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Yes I will have ball valves all over - 5 to be exact
