Thread: Replacement Pump
    May 2012
    Newtown, CT
    3
    Replacement Pump
    I currently have a Jandy Max HP 1.0 (MHPM1.0) that I am having troubles with and would like to replace. This model was discontinued and replaced by a Jandy Plus HP 1.0 (PHPM1.0). I am considering getting a two speed but would like to know whether it is worth it and which Jandy model to get. The Jandy Plus HP has a full rated 1HP in a two speed or a 1.5HP that is up rated. Which do I choose? My current pump is up rated. Also, will I be able to swap the old on out with the two speed without any wiring modifications or do I need someone to install it.
    Thanks.
    18' x 36' 19k gallon IG Vinyl Liner Pool
    Jandy CV 460 Cartridge Filter
    Jandy MAXHP 1.0 (1x1.25) hp pump
    Jandy AquaPure PLC1400 SWG
    Jandy AE-Ti 2500 Heat Pump 115,000 btu Titanium Heat Exchange
    22,549
    Re: Replacement Pump
    Welcome to TFP.
    The 1 hp full rated and the 1½ hp uprated pumps are the same pumps.
    You'll have to change the wiring to get the 2-speeds to work for you. It requires 4 wires and a switch to operate both speeds. Depending on how your pump is wired now as to how much of a change is required.
    May 2012
    Newtown, CT
    3
    Thank you for your reply. Since I will have to go up a little in hp from what I have, do you think the energy savings of the two speed will be worth the increased cost of the pump plus the installation?
    22,549
    I absolutely think it will.
    How is your pump hooked up now?
    May 2012
    Newtown, CT
    3
    Not sure. I just assumed I could have replaced it with a like model myself since the pool company pulls it out and puts it in the basement. I'll have to find someone to install the two speed with the switch. I only have two skimmers and no spa or waterfall, so I figure the lower speed would be fine unless I had to vacuum the pool. I don't have to do that too often because of the Polaris.
    Thanks for the advice.
