Thread: ColorQ and TF-100 Testing
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Performed testing on my water last night with both the ColorQ and TF-100 kit.
    Test - ColorQ - TF-100
    fCL - 3.78 - 3.75
    CC - 0 - 0.5
    pH - 7.7 - in range
    ALY - 68 - 70
    CH - 173 - ???
    CYA - 44 - 55
    SALT - - 3000
    Interestingly, I did the CH test twice with the TF-100 test kit and the water never changed color, so that would mean I have no CH in my pool??? Must be the reagants. Most of the other tests came out pretty close. Need to get salt up slightly. My fCL is normally near 8, so the low salt must be affecting that.
    Any harm in having low CH? I am working on getting CYA up further.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Re: ColorQ and TF-100 Testing
    With a plaster pool you want CH between 250 and 350. This is important, especially that it not be below 250, while being a little high is usually alright.
    What color was the CH sample water after you added the indicator dye? If it turned blue right off then your CH is zero. But if it turned red/pink your CH is fairly high. There is more information on how to do the CH test here.
    Dec 2010
    560
    When I added the dye, it remained white the entire time and did it twice. I've done this test many times with no issues, but I haven't used my test kit probably for a few months and it's over 1 year old.
    TFT-100 test kit
    Something is wrong then. Most likely your R-0011L has gone bad, or you added something else by mistake.
