Thread: Newbie, PH question
    Jun 2012
    Long Island, NY
    5
    Newbie, PH question
    Hello again,
    I have a question regarding my 12 by 36 Summer escapes pool. I have the basic "drops" tester that I picked up at Wallmart. The Chlorine shows very high, and the PH very low. My question is, can household baking soda be used to raise the PH?
    -Approx 1900 gallon Summer Escapes 12 x 36
    -Standard cartridge filter
    -Above Ground
    Re: Newbie, PH question
    No. Baking soda will raise TA. Use borax to raise the PH. Borax can be found in the laundry isle of most larger grocery stores.
    Jun 2012
    Long Island, NY
    5
    Thank you for your reply. I was not aware Borax could be used. I will give it a try later today. Just dump a bit in, and check it again?
    -Above Ground
    Oct 2011
    New Caney, Texas
    414
    Quote Originally Posted by jay11789
    You really need to read POOL SCHOOL it will help you. The POOL CALCULATOR will get you the proper amounts to add.
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Jun 2012
    Long Island, NY
    5
    Got it, thanks.
    -Above Ground
    Jun 2012
    Long Island, NY
    5
    OK, so after some education....is it safe to say that if I have had a cover on the pool for most of the week, the PH will be low?
    -Above Ground
