Results 1 to 15 of 15
Thread: How Long is shocking process?
    May 2012
    Bowling Green, KY
    38
    I am going through my first shocking process. It began 3 days ago (2 overnights). In my first overnight FC test, I was up to shock level before bed. The next AM, I had lost 18ppm; Last night I lost 7.5 ppm. Meanwhile, I have been spending quite a bit of money on bleach and my trash can is full of empty bleach jugs. I'm just wondering how long this could go on before I can get into maintenance mode maintaining a much lower FC. Any guidance would be helpful. I'm still new to the forum and pool ownership. Thank you.
    30,000 gallon, IG, Vinyl, Sand Filter, Hayward Super Pump - 3450 RPM, 1.5 HP
    South Central Kentucky
    Re: How Long is shocking process?
    If usually takes two or three days, but occasionally can stretch into a week or two.
    We can give you much more detailed help if you post a complete set of water test results.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Well, the easy answer is it takes as long as it takes. However that is not helpful. Each pool is different and each algae outbreak is different. Most will clear in 4-7 days depending on how bad the outbreak was and how well you are able to keep the water at shock level during the process. Since most folks work and can't test and replenish chlorine every couple of hours that tends to extend the length of time it takes to clear the pool.
    I feel your pain. We are restricted to 1 trash pick-up per week and that is limited to what will fit in an extra large trash can supplied by the city. While I was going through my first major shock process I started a pile of bleach bottles against the fence that we dubbed Mt Chlorox. I shared some empties with my crafty friends and took the rest (about 3 bags full of flattened bottles) to the local recycling drop off.
    As much as you are spending on bleach, clearing the pool would be even more expensive using pool store products, and would potentially cause more problems in the process as well. It sounds like you are making good progress. How does the water look?
    Love TFP? Become a
    TFP Supporter!
    May 2012
    Bowling Green, KY
    38
    Ph - 7.5
    FC - 12.5 (this am - I have now added bleach to get back to shock level of 20)
    CC - .5
    TA - 140
    CH - 260
    CYA - 50
    May 2012
    Bowling Green, KY
    38
    water is still cloudy especially in deep end - I can see main drain, but it's foggy
    Quote Originally Posted by BCannon
    one issue might be that you have to keep it above shock level. if you just raise it to shock level it immediately starts to fall so you are never actually at shock level.
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    coffeegoddss's Avatar
    May 2012
    Minooka, IL
    93
    Have patience. I started out with clear water almost a month ago (had visable dead algea and failed OCLTs) and am STILL in shock mode. Stick with it and do NOT let it drop under shock level - you'll be starting all over again! Definately put it a little over shock level to give yourself time between doses.
    AG, 10,400 gallons, filter cartridge, 2HP pump
    Coffeegoddss...bonafide thread killer!
    POOL SCHOOL...fortheloveofgawd, read POOL SCHOOL
    May 2012
    Bowling Green, KY
    38
    ok - I didn't realize I had to add bleach to get it above shock level. I have been adding enough each time to get it to shock level, and then obviously every time that I check it, it has fallen below. Thank you.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    How deep is a hole?
    There's no way to know in advance. It depends on how much organic crud is in the bottom, how good your filter is, how diligent you are about maintaining the level, and how gooey the green water started.
    If you have a full set of test results, and your CH is low enough, you could use Cal-hypo powder as a chlorine source. Empty plastic bags take up much less space than bleach jugs.
    May 2012
    Bowling Green, KY
    38
    Also, my kids really want to actually swim in the pool. If I keep it above shock level, they shouldn't swim.
    May 2012
    Bowling Green, KY
    38
    CH is 260 - full set of results above.
    TomTinNC's Avatar
    Apr 2012
    Wilmington, NC
    67
    I had to cure a messy nasty swamp....mine was in full shock for a month, but the last 2 weeks, my pool wasn't consuming much bleach. As you near the end of the process (when the high chlorine levels have killed off most of the algae and guk), you don't have to add as much bleach to maintain shock levels. The first week was the most difficult for me in the shock process. The last 2 weeks, I wasn't adding much bleach at all to maintain shock levels. Be patient. Seems like a lot, but when compared to how much you would have spent on chemicals/pool service.....it is way less. Your pool will be right as rain here shortly.
    9400 Gallon Above Ground, Vinyl Liner, 20 foot round, 4 feet deep 2 filter cartidges one Type B in the skimmer, and a C-50 hayward in the big box, 1/2 Horsepower Dynaflo Pump. TF100 Test Kit, well water, clean with Iron used for filling (CH of fill water is 450).
    May 2012
    Bowling Green, KY
    38
    Thank you, Tom, for the encouragement. Do you have a recommendation about how many ppm above shock level I should try to maintain. My shock level is 20 and I've been trying to keep it there, but I have'nt been adding bleach to take me above that figure. Since I can only check and add a couple of times a day, should I shoot for 22, 25, 30?
    Richard320's Avatar
    Jan 2010
    19,002
    If shock level is 20, and it drops to, say, 15 in 4 hours, then run it up to 25. Then 4 hours later it should be at about 20. Or whatever your numbers are.
    May 2012
    Bowling Green, KY
    38
    Thank you, Richard. Helpful.
