Thread: 2 or 3 colorlogic/intellibright lights in 20X40 pool?
    Hi there. My pool is to be dug on Friday. It is a 20X40 freeform. Kind of a oval with soft curves type of thing. I am going to go with a darker bottom for a more natural or lagoon look; either a grey plaster, or a darker pebble tec plaster. Should I go with 2 or 3 lights in the pool (and 1 in spa)? I don't mind putting in the third if it will be better as you can get these farily cheap now (less than $250 each on line) However don't want to waste money if 3 is over kill? Have not decided yet whether to go with colorlogic or the intellibright, but I have the niches and I understand the same niches fit either. Hope that is right! All my other stuff is pentair so maybe I should go with the intellibright. But it is easier to find the colorlogics at a good price. Thanks in advance for any help.
    Owner/Builder- Pool under construction- Started 4/18/08
    20X40 freeform 3 1/2" to 8 1/2' deep
    elevated 8' spa w/ spillover
    Plaster: Undecided
    Pentair intelliflo
    Pentair intellichlor
    Pentair Mastertemp 400,000 BTU gas heater
    Pentair Triton II 30" sand filter
    LED (probably colorlogic) 3 in main pool and 1 in spa
    Polaris 280 w/ booster pump
    Control System: Still working on this Intellitouch I guess but don't know all the components I need yet.
    Oct 2007
    Suwanee, GA
    31
    If you are going to go with a darker finish you need as many lights as possible. The colored lights loose much of there brightness when you have a dark finish.
    25,000 Gal chlorinated rubber painted pool. 175sf Hayward cartridge filter. 1 1/2 hp AO Smith pump.
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    My pool is a 22 x 34 custom built. Although I went with white plaster, I would suggest at least 3 lights in the pool with the darker finish you plan to use. Obviously the darker finish will tend to absorb the light and not reflect it. Therefore, another one(3 lights + 1 spa) would help to insure coverage. Here is a shot of mine at night with 2 Color Logics in the Pool and one in the Spa. Good luck.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    Spectacular!
    awesome pool!
    Plaster: Undecided
    Pentair intelliflo
    do you have?
    a deep end in your pool? Is that a swim out in the pic that has the 2 different levels? Thanks
    Plaster: Undecided
    Pentair intelliflo
    divnkd101's Avatar
    Mar 2007
    587
    Re: do you have?
    Quote Originally Posted by cword
    Yes, that is a deep end. I have 2 love benches in the pool. The one on the left has an additional step added to make it a little easier to get out of the pool. Works great for the older folks and my lab. Good luck with your decisions.
    MIKE
