Correct TA for pebblesheen
JAWS
May 23, 2012
9
Manteca, Ca
Hi all,
Been lurking for awhile and recently joined. I've learned a lot from this site, thank you (Chem Geek, I live in Manteca and I can feel your brain power from here!). I have a pail of Proteam Supreme Plus waiting in the garage to serve me and my family. I want to make sure my TA/PH is correct before adding the borates. I'm getting conflicting recommended TA levels everywhere I turn. The PB is adamant that the level should be 125-150, yet here and elsewhere I see lower levels are preferred. I can make any adjustment necessary, and just need a target number. Appreciate any feedback from members here on an appropriate target TA level for Pebblesheen?
Jim
The higher TA recommendations may be based on the assumption that you will use pucks which are acidic and lower the pH (so the higher TA would help stabilize the pH). But, if you are using bleach ... that is not the case.
In fact, you have twin sheers I see, so that aeration is going to tend to make the pH drift up (SWG have the same effect). So, in your case, I would think something lower for TA, like in the 70 range, may help hold the pH down due to the sheers.
What are you levels now? I would recommend seeing where you pool equalizes with normal use before adding the borates ... no real hurry to add them really.
The PB did indeed push the pucks (with an in-line feeder) and in my ignorance I went that route. I'm now in transition, just finished a 75% drain which reduced CYA to 38 (from 151), and using pucks/shock just to restart. I plan to use bleach moving forward. The water looked great before and still does, but you make a great point, I should wait until the water stabilizes under the new program before adding the borates.
I appreciate the feedback of TA 70 based on my setup and the BBB approach, jblizzle, as I've never pushed TA below 100 and wanted a little reassurance, thanks!
Latest numbers are below, based on my 4-way standard test kit plus CYA and hardness numbers from the pool store (K2006 is en-route).
FC - 3
CC - 0
pH - 7.6
TA - 130
CH - 125 (total hardness)
CYA - 38
Will do. Before the drain, CH was about 300 and I was getting some scale, so I used 2/3's soft water on the refill ending up with a 125 reading. Now I realize the problem was not CH but the higher PH I kept battling. Keeping TA/PH at recommended TFP levels should do the trick.
CH is only part of the puzzle for scale ... pH plays a larger role so if you let it stay above 7.8 for any length of time, that could certainly have been the reason for the scale.
Well, ignore what I just wrote as I now finished reading the second half of your post and see that you "get it" :goodjob:
I adjusted TA/PH and finally added the Proteam Supreme Plus on Friday. Left the filter on over the weekend while away. Before and after numbers are below. Expected TA to go up a little, but not this much! It usually wants to hover around 140-160. The borates did this?
I will say the water feels great! If my mind isn't tricking me it looks a little more sparkly too.
Before adding PSP on Friday:
FC - 5
CC - 0
pH - 7.5
TA - 95
CH - 150 (slowly raising this)
CYA - 55
After adding PSP on Sunday
FC - 3
CC - 0
pH - 7.5
TA - 230-240 (tested 3x, twice on K-2006, once on the old 4-way)
CH - 150
CYA - 55
That is very strange. While I have heard of that happening one or twice before, it is extremely uncommon and not caused by borates. Adding borates will raise the TA by 5, or maybe 10, but not by a huge amount like that. I suppose it is possible that the ProTeam Supreme Plus might have had the wrong chemical in it, but that seems extremely unlikely.
Contacted ProTeam today and was happy to see that they were concerned with what happened. They confirmed the impact to TA level should have been negligible. They asked for the batch number on my container and seemed sincere that they were going to investigate the issue from their end. He is also sending me a bunch of Muriatic Acid to compensate for what I'm using to correct the situation.
All in all, despite what happened, I was very happy with how ProTeam responded. They handled it well, and stand behind their products.
I suspect another driving factor here is that ProTeam (unknown by me at the time) has apparently not gone through the steps necessary to ship Boric Acid products to California, yet I was still able to make a purchase through PoolGeek (who btw couldn't care less when I contacted them).
