Thread: Aqua Mate brand CYA
    Jul 2008
    Seacoast, NH
    250
    Aqua Mate brand CYA
    I've been buying Aqua Mate cya last summer and this spring because a local Ocean State Job Lot carries it and it is cheap, 13.99 for 7 lbs. It has been a struggle to get our cya up to the level we want and, duh, it just occurred to me that maybe the cya isn't 100% cya. So, I read the label and all it says is " active ingredient: cya". I read the table on the side re how much to add for x gallon pool to raise cya y ppm. Based on that, I would estimate it is around 80-85% cya. But, based on my results, I think the percentage is more like 60%.
    Anyone have experience with this brand. I won't be buying it again, but I still have about 5 lbs left.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Aqua Mate brand CYA
    See if the label matches any of the info on this MSDS http://www.baleco.com/files/Baleco_Cond ... r_MSDS.pdf
    Jul 2008
    Seacoast, NH
    250
    Yep, that's the stuff. 98%. And yet it is a struggle to get my level above 40 or 50.
    1.5 HP Pump
    Richard320's Avatar
    Jan 2010
    18,988
    Maybe your pool holds more water than you think?
    Jul 2008
    Seacoast, NH
    250
    That's a possibility, but the pool calculator works perfectly for everything other than cya when adding chemicals and assuming 19000 gallons. It's a mystery.
    1.5 HP Pump
