Results 1 to 1 of 1
Thread: The Kleanzit Calcium Remover
    Jul 2007
    Sahuarita, AZ
    Has anybody used one of these before? I was shopping at my local Frys (supermarket) and picked up some Acid while I was there and in their pool section saw this. I've had some calcium deposts on my tile, mainly near my spa spillover and thought I might try this. Previously I'd used a scrub brush dipped in some Muriatic Acid and it worked well but I didn't love working with the acid.
    The Kleanzit worked really well... scrubbing at the extremely hard calcium deposits for a few seconds pretty much rubbed it right off. It seemd to foam a bit like the acid does so I'm wondering what exactly it has in it. It had some sort of crystals embedded in it also. The only downside I could see is it did leave some debris (kind of like an eraser) which I just washed into the water. I'm unsure if they'll dissolve or not. Either way, I'm not too concerned as my cleaner will eventually sweep them to the drain.
    I'll definitely use it again... I just used it for the very obvious parts around the spillover but next time I'm in the pool I'll give all the tile a good cleaning. It cost about $12.00.
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
