Results 1 to 9 of 9
Thread: Drain Cap to sand filter broke? Question
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    My drain cap split in half and dang near emptied the pool into the backyard and flood my basement. Luckily I caught it and my sump pump handled the water.
    My question now is this. I ordered a cap from pool center and it will come in 1-3 days, but what can I do in the meantime?
    I think if I put some epoxy on the outside of the cap and let it harden, that it might stay good till the new one arrives. What do you guys think?
    I am gonna look tommorrow after work to pickup some epoxy and start with that. Maybe it will allow my pump to run at least for a few hours each day till the cap arrives.
    My other alternative is to call my local pool store 100 miles away and maybe they would have one? If they do, then I plan to drive there on Friday to pick it up. Worst case is that the pool would sit one or two days without running and get a little green till my part arrives.
    Anyone have a better idea?
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    Sep 2009
    Greentown, IN
    914
    Re: Drain Cap to sand filter broke? Question
    I think I would turn my valves off and see how soon I could get a replacement.
    If you do try the epoxy for a temporary fix and it holds, I certainly wouldn't leave it running when I wasn't home... would hate to think of running the water too low and losing a pump too.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Aug 2011
    Metro Atlanta, Georgia
    161
    Get a pvc threaded cap at the hardware store, use a hose gasket as a seal. Don't overtighten, as it will probably leak a little and you don't want to mess up the threads on the tank.
    My cement pond is a 36K gunite 20X40 built in mid 1960s, Hayward S244S filter, Aquarite SWCG, Jandy 1.5HP 2sp, TF-Test kit and Nitro Wall Climber
    Sep 2009
    Greentown, IN
    914
    Good idea Buford!
    Test kits compared
    Purchase test kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    How big is this cap? You can buy rubber caps with a hose clamp for drain pipes.
    http://www.americanvalve.com/flex/flexpipecap.html
    Feb 2008
    Milford, CT
    333
    Same thing happened to me a few years ago. I used aqua mend from home depot to seal it up. It's a stick of putty that you knead together into a uniform color then apply to the crack. I think it's called something different now but they still have it.
    Held that way for years until I finally remembered to get a new drain cap BEFORE the season started.
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    May 2008
    Jamestown, ND
    519
    Richard, I like your flexible connectors. That would be a temp fix till the part arrives. I am going to try my pool store today first and if its a matter of running 100 miles to get it, then I would either tonight or first thing in the morning. If they dont have it, then I will look for the rubber flex gasget to run it a few hours each day WHILE I AM HOME of course to assist with keeping the algae at bay. 6-8 hours a day should do me till the part comes online as I did go ahead and order a couple from them too as a backup. Having a couple extra on hand is not a bad idea to have as those caps do get brittle over time.
    Thanks guys for your suggestions.
    I will let you know what happens or what I ended up doing.
    Chad R.
    22,553
    How about putting your multiport valve on recirc just to circulate the water in the pool till you can get it fixed? It won't be filtering but at least you can still chlorinate, etc.
    May 2008
    Jamestown, ND
    519
    Good one Dave. I actually read on this post earlier to do that so that is what I did today and then I ran to the pool store. Took 3 hours round trip, but they had the part and the cap is on! Its now running and life is good with a Beer in my hand. Wow it was hot here today. Got to 91. Pool felt awesome!
    thanks guys for all your suggestions. In the meantime I picked up a spare cap just to have one on hand for down the road issues. They are only 8 bucks with tax so made sense to carry a spare!
    Cheers guys and gals!
    Chad R.
