Thread: SWG TA recommendations
    Jul 2011
    Las Vegas, NV
    37
    My Aqualogic SWCG recommends a TA level of 80-120 ppm, but Pool School suggests 60-80 ppm instead. The manual also recommends a pH from 7.2-7.6, compared to Pool School's 7.5-7.6.
    Right now, my TA level is about 100, and the pH seems firmly pegged at 7.5 (hasn't moved in the last week, despite using the pool a lot).
    Should I work on decreasing my TA level?
    33k in-ground plaster pool and spa / Goldline T-15 SWG w/ Aqualogic controller / RS2000 Hayward pump / Pentair Clean & Clear Plus 420 sq. ft. cartridge filter
    Re: SWG TA recommendations
    If your PH is stable, then don't worry too much about the TA. I expect that over time you will find that PH tends to increase. If that becomes annoying, then reduce your TA.
