Thread: How much sodium bisulfate
    Just how much sodium bisulfate will I use as opposed to the muriatic acid.14000 gallon pool.The calculator says to use 51 pounds of borax.
    22,550
    Re: Almost ready for Borates!
    Jim -- You do realize dry acid adds sulfates to the water don't you? Muriatic is a better solution. You can use the Pool Calc to figure the equivalent amounts.
    I was just worried that such a large quanity of muriatic acid would be hard on the vinyl liner.
    22,550
    Re: How much sodium bisulfate
    As long as you follow the procedure there's no danger to your liner.
