Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Just opened my pool...yikes, it looks awful!
    sjdhr75's Avatar
    Jun 2012
    Ohio
    16
    I have a 24 foot above ground pool with a Hayward pump. The leaf cover fell in and my pool was full or nasty rotten leaves. I used a leaf rake and got most (as much as could be seen) off the bottom and then started shocking my pool. I have had the pool for 4 years and I have never had a problem until now so I am at a loss as to what to do. I have read alot of the pool school but I am still not getting the results I want. The water is now a cloudy blue/light green and I can see little white particles floating that look like dandruff (dead algae?). I put 10 gallons of bleach in last weekend and my FC is still at zero. I have used ph.minus and clarifier too. I just picked up 3 lbs of hth super sock 'n swim and I have 4 gallons of bleach I haven't added yet. Just tested and here are my latest result-FC 0, pH 6.4, TA 80, TH 200, and Cyan 0. Can someone give me some steps of how to clear this up. It has been really hot in Ohio and I would love to get in that pool! Lol...
    Thanks so much!
    Stef
    24' Outback Above Ground
    13,500 gallon
    Hayward Sand Filter
    Nearly everything you do is of no importance, but it is important that you do it~Mahatma Gandhi
    Re: Just opened my pool...yikes, it looks awful!
    Welcome to TFP!
    Without any CYA in the water you will lose all of your chlorine to sunlight each day. It is extremely difficult to kill algae when that is happening. You should raise the CYA level to around 30 right away, and then adjust it further after the algae/debris is all cleaned up.
    Also, your PH is way too low. You should bring the PH up to at least 7.0 right away. PH below 7.0 can damage the pool.
    [shock:32hr9vd2]Once you have taken care of those issues, it is time to shock the pool.[/shock:32hr9vd2]
    sjdhr75's Avatar
    Jun 2012
    Ohio
    16
    What do I use to add cyanuric acid? Does it just say cyanuric acid?
    Thanks so much for the welcome and you all know your stuff
    Stef
    13,500 gallon
    Hayward Sand Filter
    22,551
    It will most likely say stabilizer but the ingredients will be almost 100% cyanuric acid.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Walmart sells HTH brand CYA titled "Stabilizer". It dissolves quickly, especially if you help it along with squishing a sock that is hung off the ladder or in front of a return frequently. Use a tube sock, or any sock or nylon/stocking. It won't ruin it and can be worn on a foot afterwards. Determine the amount of CYA to use to bring your pool up to ~30-40ppm (use pool calculator), measure it out and put into the sock. Rubber band the top, hang somewhere in the pool and drop by every now and then to squish/disperse the CYA into the water. When it's dissolved, you're done and can assume the intended level is what is in the pool (don't bother testing CYA for a week or so, just assume. If you put it in and calculated properly, it's in there).
    Whatever brand you choose, just check the ingredients. It should say "cyanuric acid". If it doesn't it isn't CYA/Stabilizer.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    sjdhr75's Avatar
    Jun 2012
    Ohio
    16
    Thanks so much for the quick responses! I will stop and get some tomorrow
    Stef
    13,500 gallon
    Hayward Sand Filter
    sjdhr75's Avatar
    Jun 2012
    Ohio
    16
    Ok I stopped at Walmart and the only stabalizer they had was in a pool opening kit, so I got 2 of them. It has 2 containers, each with 15 oz. of stabilizer/conditioner. How much do I need to use? Also if I cannot test the cyanuric acid for a week or so, I also need to raise my pH and shock. Can I go ahead and raise the pH and what is the best way as to not affect the other values and when can I shock, lol. I am clueless =)
    13,500 gallon
    Hayward Sand Filter
    sjdhr75's Avatar
    Jun 2012
    Ohio
    16
    I just put in the 30 oz of stabilizer/conditioner that I have with the sock. The pool calculator says I need about 75 oz but I went ahead and added what I had so it could start dissolving. How long until I can start adding bleach? I backwashed before I added the stabilizer/conditioner and the water was low so I started adding some more. Where the water was low I could see like a scaly line around where the water line was and when I tied the sock to the ladder I could feel it on the ladder too. Do I need to do something else to get rid of this or will the chemicals and adjustments I'm making take care of it?
    13,500 gallon
    Hayward Sand Filter
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    How many gallons is your pool?
    Adjust your pH now to at least 7.2. No more ph minus!
    Get some more CYA as well. You may be up to 15ish. I believe you'll want 30 to start shocking.
    As soon as your pH is above 7.2 and you have the other CYA added, you will want to begin adding the bleach. This will be an hourly process, so buy lots of it.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    sjdhr75's Avatar
    Jun 2012
    Ohio
    16
    I'm gonna stop and get more of the stabalizer on my way home from work today. So do I add the borax like the stabalizer in a sock or just sprinkle it in? Will the ph raise pretty quickly?
    13,500 gallon
    Hayward Sand Filter
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    From Pool School in the Recommended Pool Chemicals Link.
    "Borax is available as 20 Mule Team® Borax Natural Laundry Booster. It is sold in the laundry detergent section of most larger grocery stores and some big box stores. Borax is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return."
    ~~ Allison ~~
    sjdhr75's Avatar
    Jun 2012
    Ohio
    16
    Thank you!
    13,500 gallon
    Hayward Sand Filter
    I've noticed something in a few threads... when you say you had 0 CYA, where did that result come from..?
    I wouldn't trust any test results that didn't come from a TF-100 or Taylor K2006. If 0 CYA is inaccurate and there is already some there, adding more will put your level higher than you think.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    One of those kits from Wally world has a cya test in it. I've found it just as accurate as the tf kits.
    The stuff you want from Walmart, if I'm not too late, looks like this. The coke can is for a size comparison.
    I've got nothing to add, listen to these people and you'll have an awesome pool! They're really water wizards!
    Oh, and yay Ohio!
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
    sjdhr75's Avatar
    Jun 2012
    Ohio
    16
    Thanks for the extra advice everyone! Ok my levels now are FC 5/10, pH 7.8, TA 120, TH 200, CYA 30-50. I've kept the FC up all weekend and my levels are still good but my pool is still like a cloudy blue. What is the next step to clear that up? I have been on that pool all weekend checking and rechecking,lol. It was sooooooooooo hot today and I wanted to get in there so bad =(
    Yay O~HI~O!
    13,500 gallon
    Hayward Sand Filter
    sjdhr75's Avatar
    Jun 2012
    Ohio
    16
    Still blue and cloudy Any ideas?
    13,500 gallon
    Hayward Sand Filter
    22,551
    Without a good test kit you're just guessing. The reason I say that is that those look like test strip numbers.
    All you can do is try and keep your FC up and keep the filter running until it clears.
    You really should order a good test kit if you don't already have one.
    38,371
    What kind of a filter do you have? (pretty sure I did not see it mentioned). While I appreciate your signature, it would be more helpful to add your pool information there as well.
    Sand filters can be a little slower clearing the water. Make sure you are backwashing when the pressure goes up 20-25% of the clean filter pressure.
    And I have to agree you will be much better off ordering one of the recommended test kits ... best investment you can make.
    sjdhr75's Avatar
    Jun 2012
    Ohio
    16
    I have a Hayward sand filter.
    13,500 gallon
    Hayward Sand Filter
  20. Back To Top    #20
    sjdhr75's Avatar
    Jun 2012
    Ohio
    16
    Well I put in a 1/2 bottle of clarifier tonight and I just went out and tested the water. My levels are FC 1-2/pH 7.5/TA 120/TH 200/CYA 30-50. Still looks cloudy blue. I have been running the filter 24/7. How can I clear this thing up by this weekend? My kids are about to kill me wanting to get this thing done! Help!
    13,500 gallon
    Hayward Sand Filter
