Results 1 to 8 of 8
Thread: Is this a mistake?
    May 2009
    Trenton NJ
    497
    Is this a mistake?
    My cya was 45. I have a salt water gen. So today I put enough cya to raise it to 70. Since I am still shocking, now I need to use higher doses of chlorine,correct? In retrospect I should have waited til I was done shock pool.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Is this a mistake?
    You probably would have been better off waiting. Did you put it in the skimmer or in a sock?
    30,426
    That is correct but it's not a deal breaker...just go to the FC/CYA chart or the pool calculator and use the appropriate dosage.
    That you figured that out indicates you are rapidly becoming a BBB'r
    May 2009
    Trenton NJ
    497
    I still have about 2 lbs. in a sock. Should I take it out for now? Can I use it later?
    SW Indiana
    9,199
    Quote Originally Posted by ethany
    Yes you can use it later. Just put the sock in a bucket someplace.
    May 2009
    Trenton NJ
    497
    I did learn so much from u guys/girls. It's the only way to crystal clear water. What's funny is watching the look on my nosy neighbors face when I dump bleach in the pool. I would explain this system to him but he is so closed minded it would fall on deaf ears.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Your sparkly pool will do the 'splainin for you. :~}
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Sep 2009
    Greentown, IN
    914
    You will find that many don't understand that standard bleach is the same thing most use in their pools to keep them clear, it's just in a diluted and less expensive form. Even when you show them the active ingredient is the same you will often get the same disbelief.
    Enjoy your clear and sparkling pool water... And let your neighbor wonder about it
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
