Results 1 to 12 of 12
Thread: White Water Mold
    White Water Mold
    We've been having a lot of trouble with our Jandy 1400 SWG this year. We opened the pool early and a week later, we got error 121, so after going through a bunch of stuff we replaced the cell. Then we have been dealing with errors 123 and 188 for a couple of weeks. Looks like we might have it fixed with a replacement DC cord, but I'm not holding my breath.
    In the meantime, our water balance has gotten out of control. CYA had been low (according to pool store) and we just couldn't seem to get it up. Even after dissolving it in various manners and adding and adding. Then all of the sudden, this white, tissue-like, slimy gunk appeared. It looks to be White Water Mold. We decided to open up the filter to see if the CYA was getting caught up in there or something. When we did, we found that it was completely clogged with pink slime.
    We replaced the sand on Saturday and have been shocking the pool every day. We added some more CYA, as the test strips we were using were showing it below 30 still. It finally took. We've been shocking and brushing the pool every day.
    I got my new test kit in the mail today and just ran all of the tests. I guess my question is, now that we don't see the mold anymore, we still think it could be in pipes, etc. What to we do to make sure it doesn't come back? That we completely eliminate it?
    FC - 8.5
    CC -11.5
    pH - 7.2
    TA - 90
    CH - 390
    CYA - 80
    26,000 gallons, sand filter, IG, vinyl, Jandy 1400 SWG
    22,551
    Re: White Water Mold
    Are you sure about the CC's? If so then you're not done shocking.
    You need to bring the FC to shock level for your CYA of 80 and keep it there as often as every hour till you pass the OCLT..
    Feb 2012
    Phoenix, AZ
    728
    How are you adding your CYA? This should NOT be added through the skimmer, but rather in front of a return jet (typically in a sock). Also, keep in mind that CYA can take up to one week before it shows up on a test. Do you know how much CYA you added total?
    And yes, as Bama said, that CC is very high. Keep shocking.
    Oops, 11.5 is TC. CC is 3.
    So, I need to keep FC at 30 until I pass the OCLT, right?
    THANK YOU!
    22,551
    That's right. That's 13 gallons of bleach or 9 large jugs from 8.5 FC. I'd start with about 35 large jugs.
    Oh, wow. That is a lot more than I've been doing. Need to make a trip to the store.
    22,551
    Yeah, it takes a lot to begin with but hopefully you won't have to add that much each time for very many times. Hopefully it'll start holding pretty quickly.
    I had white water mold last year - and you described it exactly as I did: White tissue-like slimy floaties. I wasn't tesing or doing BBB last year - but I can tell you it cost me well over $100 when said an done with PS chemicals (Powerfloc, and other adjustments). I dont think you will spean nearly that much in bleach (at my costco that would be over 30 large bottles of bleach)
    This year Im so thankful that I have a good test kit, and have started with BBB. Now I will be able to understand what is happening in my water - rather than watching my money go down the main drain (pool pun intended) when problems like this occur.
    Good luck - and keep shocking!
    20K IG White Plaster - Hayward 1.5 HP Pump - Anthony DE Filter - TF100 Test Kit
    Well, to update y'all - we're still shocking. We've been scrubbing and scrubbing and this stuff is still hanging on. How is it continuing to grown with so much chlorine present? We've gotten the CC down from 3.5 to 1 since the beginning of the process, so at least there is progress.
    However, when I run my hand around the side, I can feel re-growth of the mold each day. Granted, it is not as bad as it was, but we are scrubbing and shocking every day. Is this typical?
    What is your FC? With a cya of 80, you will have to keep FC high to reach shock.
    This morning we are at FC=36.5 and CC= 1. Though it was really close to clear at one drop, I added one more for total clarity for the CC = 1.
    Just now, without adding anything all day, we're at FC=26 and CC=0.5.
