Thread: Hayward Ecostar VS vs. Pentair Inelliflo VS Pump
    Jun 2012
    Austin, TX
    97
    One of our pool builders quoted us Hayward products and the other Pentair. Both of the quotes feature the same size cartridge filter of each respective brand and the variable speed pumps of each brand.
    Which is considered the "best" pump or brand of equipment. The bids are only about $500 apart (the Pentair bid is $500 higher than the Hayward bid).
    All other things being equal, which should I choose?
    32x15 freeform gunite pool (approx 15,000 gallons) with a 7x7 raised spa with 2 spillovers - tanning ledge with 2 bubblers - All Hayward Equipment - ARQ15 SWCG - 400btu heater, 60sq ft DE filter - 2HP EcoStar VS pump - Oklahoma flagstone coping - MasterTile MASMIX 3 1x1 - Sundek - Crystal Stones Smooth Caribbean Blue - TF-100 - Doheny's Discovery Robot
    Feb 2012
    Phoenix, AZ
    728
    Re: Hayward Ecostar VS vs. Pentair Inelliflo VS Pump
    Honestly, both of those brands and models are solid! It is a matter of personal preference, and I am pretty sure the members here will be split down the middle.
    If you are installing (or planning to install) an automation system, then the biggest consideration is just making all of the equipment match. Which it sounds like you have under control.
    Jun 2012
    Austin, TX
    97
    I had kind of come to the conclusion that they were both good, but the last pool builder I met with said that Hayward equipment is only seen on "lower-end" pools and that they only use Jandy and Pentair. Also, out of the 5 pool builders we met with, only 1 of them is recommending Hayward. This whole process is stressing me out
    Sep 2007
    Central NJ
    59
    I mixed & matched brands on pump/filter (Intelliflo pump & Hayward Swimclear cartridge filter). I went with the Hayward filter strictly because of the location of the filter drain outlet -- it is 180 degrees opposite the connections to/from the pool.
    With my plumbing/equipment setup, having the drain directly under the filter inlet/outlet (as in the Pentair cartridge filters)didn't make sense and would be awkward to access. YMMV.
    Quote Originally Posted by jk7228
    Must be a regional thing...sounds like to me.
    Pool service techs do seem to have something against Hayward more often than not. But pool owners find Hayward and Pentair to have very similar products with similar features and quality available from both.
