Results 1 to 8 of 8
Thread: 6G's to replace liner?
    Cary, IL
    29
    I have a 20x40 IG pool and just received a quote to have the liner replaced.
    Replacement includes:
    - drain, remove old liner, chlorine rinse for bacteria control, smooth out any rough spots, patch any large cracks, caulk seams, clear debris, install liner
    - 27 mil liner
    - new faceplates and gaskets (I have 4 returns)
    - 1 load of trucked in water
    Total cost is $6000
    Does this sound about right? I have no idea but am thinking of getting 1 or two other quotes. This particular quote came from our pool builder and we do trust them to do good work but I want to make sure I'm keeping them honest!!
    Thanks!
    Bill Boehm
    Cary, IL
    40,000 Gal, 20x40 IG Liner with water slide and swim out. Auto-cover, Polaris 280, Pentair (Sta-Rite) VS-3050 pump with EasyTouch Control System and Laars LG250N Heater.
    30,420
    No doubt....get another quote.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Yowza - they sure think they are made of gold - or is it the water that is golden? I'm with Dave on this one.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    Sounds like they're putting the screws to ya!!!
    16' by 32' cornelius AG vinyl liner, 6' deep end, 14500 gal.
    Hayward 250 Lb sand filter
    Hayward 40 GPM pump
    2-2' by 20' sun grabber solar heater.
    4 gal Liquidator. BBB
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Yeah definately shop around. We replaced the liner in my moms 18x36 I/G about 3 yrs ago and it was about 2k.
    You can rent a sump pump from Home Depot and drain it yourself and also refill it yourself. That is what we did.
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Cary, IL
    29
    Thanks all
    Here's the breakdown:
    Labor $2800
    Liner $2600
    Faceplates and gaskets $400
    1 truckload of H20 - $200
    The 27mil liner is more expensive than traditional 20mil liners but we really wanted to go with something that's going to last this time around. But even at that, $2600 seems a bit high. And from what I'm hearing, $2800 in labor is WAY too high.
    1 truckload of water is just enough to set the liner. I don't remember how many we needed when we first built the pool but probably 3 or 4 truckloads total.
    I'll definitely be getting a couple more quotes.
    Thanks for the insight!
    Bill Boehm
    Cary, IL
    Dec 2007
    Central New York
    504
    Re: 6G's to replace liner?
    Quote Originally Posted by bboehm
    I don't know what area of the US you are from: but if the other quotes you get are in the ballpark of the first, I think your last sentence says it all.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Cary, IL
    29
    We are in the NW suburbs of Chicago. If anyone knows of a good, reputable installer that they would recommend, I'm all ears!!
    I called Arvidson today (another local pool co.) and they said roughly $3500 to do the liner replacement. That's alot more in line with what I had originally envisioned.
    I'll be getting a couple more quotes.
    Bill Boehm
    Cary, IL
