Results 1 to 9 of 9
Thread: ph going crazy
    ph going crazy
    Need some guidance?
    Ph is rising .2 daily. Am doing the BBB thing. Filter runs 9 hours daily. Very low pool useage at this time of year.
    FC 5
    CC 0
    PH 8.0
    TA 100
    CYA 50
    CH 55
    Have been adding a 182 oz jug of 6% clorox nightly. What is making the Ph climb? Have been adding MA to lower Ph.
    27K IG Vinyl Pool
    1 HP Hayward pump
    Hayward sand filter/ 3720 GPH
    Taylor K-2005 & K1515A test kits
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: ph going crazy
    Do you have any water aeration occurring...fountains, waterfalls, lots of splashing, a return pointed towards surface, etc?
    Aeration will raise ph.
    Also, your TA is at the upper end of the recommend range for bleach users (70-90+ ppm). By adding MA as you are, you also will be slowly lowering your TA and eventually it should get down into the recommended range. Then if the ph climb is being caused by the slightly high TA now, it should reduce.
    Re: ph going crazy
    One return near the steps is slightly breaking the surface. I will turn it downwards and see if that makes a diff.
    27K IG Vinyl Pool
    1 HP Hayward pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: ph going crazy
    Quote Originally Posted by arleetrip
    Need some guidance?
    FC 5
    CC 0
    PH 8.0
    TA 100
    CYA 50
    CH 55
    Keep your pH in the lower end of the range. 7-7.2. This will eventually lower your TA and reduce the inclination for the pH to rise.
    Re: ph going crazy
    Lowered TA to 7.0
    ph is still climbing at a rate of .2 day day. What is causing this. I'm having to add 25 oz. of MA per day. Last year I only had to add MA twice in the whole season.
    27K IG Vinyl Pool
    1 HP Hayward pump
    30,432
    Re: ph going crazy
    Based on the information provided, the pH rise is inexplicable as far as I can see. I am posting to emphasize that regardless of the cause, it is important that you keep your pH in the 7'S, no matter how much acid it takes.
    Wish I had an idea for the pH rise.
    Re: ph going crazy
    When TA gets down to around 60, change to only lowering PH to about 7.6.
    Re: ph going crazy
    1. The acid/aeration process to lower TA:
    2. Add acid to lower your PH to between 7.0 and 7.2 (this also lowers TA)
    3. Aerate until PH rises to around 7.6 (the only way to raise PH without also raising TA)
    Repeat steps 1 and 2 until you reach the desired TA.
    How long should I wait after adding MA to begin aeration?
    27K IG Vinyl Pool
    1 HP Hayward pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: ph going crazy
    Right away is fine since the ph will balance in your pool ~1/2 hour and the aeration to raise is a slow process.
