Thread: Rain
    May 2012
    new york
    27
    Rain
    Hello everyone. My pool is doing well thanks to everyone on the forum. It has rain for 2 days in ny and I have tested the h2o and I notice a spike in the FC and the ph I thought adding more water from the rain will lower the levels
    26x46 Inground Pool SWG 36,000 gallons vinyl liner with 12' cement walls. cement steps, vamiculite bottom through out pool.Bio guard SWG ms-10 system, Mini max NT Gas Heater,Pentair Cartridge Filter CCP4200, pentair whisper Flo Pump 2/.33 hp.
    30,424
    Re: Rain
    If you saw a spike in FC, you have a testing error. Rain contains no FC.
    It will also have minimal affect on your pH simply run the pump and blend the water and take a pH reading after the rain stops to double check.
    May 2012
    new york
    27
    Re: Rain
    I am running my pump for 12 hrs on low. When we use the pool we run it on high. U think with the amount and size of the pool running it on low is sufficient amount of time
