Results 1 to 8 of 8
Thread: Polaris 3900
    Polaris 3900
    I just purchased a new Polaris 3900. After getting it home I noticed a lot of dust on the box and the unit was also a little dusty ,it was a sealed box. after opening it I noticed the tail sweep didn't have the newer tail sweep end. I called Polaris and asked them about that and they told me that the unit was manufacture in March of 2011.I has guess it has been sitting in a warehouse. The Polaris tech wasn't that much help. Have there been any updates to the 3900 since March of 2011? should I return and ask for a newer unit?
    John (DIYer). Concrete, approximately 13,000 gallon inground pool with adjoining concrete spa. Approximately 35 years old. Legacy Anthony Sta-Rite bronze pump CF6, VA-26 filter,(2 sets), new Rheem propane heater for spa.
    Feb 2012
    Phoenix, AZ
    728
    Re: Polaris 3900
    Yes, there have actually been quite a few changes to this cleaner since March 2011! If I were you, I would request the item to be changed for the latest model.
    Changes include:
    An 8-point mechanical upgrade
    Removable head float
    A chain guard has been added to ensure the drive chain is always aligned on the drive pulley
    Improved single-side wheel design
    Upgraded gearbox
    New Tail Sweep
    Re: Polaris 3900
    Thanks Blake, I went back today and I received a refund, I gave them the chance to get me the latest model but they didn't seem to want to do it. So, I just went to another dealer and got another one.
    Feb 2012
    Phoenix, AZ
    728
    Re: Polaris 3900
    Quote Originally Posted by jinjil
    good call
    Another thing...there is a $200 rebate on the new cleaner. Make sure you cash that in!
    Re: Polaris 3900
    Blake, my booster pump pulls from the return, is it normal for water to be always flowing thru the pump? Never notice that flow before until I put the Polaris fitting in the booster pump return and now when the cleaner is not running and the filter is running there is a little flow passing thru the cleaner. O, that $200 is going towards a salt system.
    Jun 2010
    Dripping Springs, TX
    125
    Re: Polaris 3900
    That is normal Jinjil - my 280 trickles a bit of water through it when it is hooked up as well.
    SF
    17K gallon IG freeform Pebble-Tec pool w/ raised spa/waterfall, Hayward 6020 DE filter, Tristar 1 HP circulation pump, Tristar 2.5 HP spa pump, Silencer 2hp blower, Aquarite SWG, Polaris 280 w/ booster pump, Hayward Universal H-Series 400K LPG heater, Ultrapure Ozonator 25, Aqualogic PS-8
    Feb 2012
    Phoenix, AZ
    728
    Re: Polaris 3900
    Normally booster pumps are run from some part of your return line. Since there is no check-valve for the Polaris hose, it is completely normal for some water to flow through that line when the main pump is on.
    Re: Polaris 3900
    Thanks guys, appreciate it.
