Results 1 to 7 of 7
Thread: How to stop water flow to change the pump?
    Jun 2012
    Louisville, KY
    50
    I've learned a ton reading through pool school and various threads over this past weekend.
    The pool I'm inheriting with the home we're purchasing needs a new pump and filter (...as in the current pump will not power on). I'm confident in my ability to plumb the pvc up as I've worked with pvc fittings many many times in the past. What I cannot figure out is how to plug up the pool in order to disconnect the current pump and install the new one. There is no valve on the current set-up (I'll be adding one during this process) and the pool is full of water.
    School me!
    38,000 gallon IG pool Plaster bottom & fiberglass walls
    Jandy FloPro 1.5hp, 2-speed pump
    Hayward S310T2 sand filter
    CompuPool CPSC36 SWG
    38,275
    Re: How to stop water flow to change the pump?
    Isn't the pump above water level? If so, no water will come out.
    Mine is right at water level. I had to plug the hole in the skimmer (main drain is plumbed to the skimmer also) to keep the water from flowing out when I re-did my pad.
    Jun 2012
    Louisville, KY
    50
    It seems so simple now that I read it. Good old gravity.
    Also, is the main drain being plumbed to the skimmer the standard set-up for most pools?
    38,275
    I think it used to be ... hard to say.
    I wish the main drain and skimmer were plumbed separately to the pad because:
    1. You have more control over where the water comes from
    2. You can drain the pool using just the floor
    3. You have more pipe area to suck through so the head loss is less and you get higher flow rates
    EDIT: My current pool was built in the mid 1970s. My last pool I had built in 2002 (when I knew nothing). Both had the single main drain plumbed to the single skimmer.
    Quote Originally Posted by thegame9377
    Unfortunately, that is done way too enough. It is far better when it is plumbed back to the equipment pad.
    Feb 2012
    Winston Salem NC
    161
    My eqipment is below water level. How would you go about making a ball valve change if needed? Are their "caps" or anything you can put over the skimmer and/or main drain?
    I don't need to, but it is something that I thougth about last night....
    18x36 IG Vinyl. ~29k Gallons.
    Pentair CCP420 Cartridge Filter
    Pentair Inteli-flow VS Pump
    Hayward Goldline SWG
    Tigershark QC Robot
    38,275
    I used a toilet bulb / seal to plug the skimmer hole. Could not find the correct fitting.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
