Results 1 to 12 of 12
Thread: Pump Timer
    Pump Timer
    I need to replace my timer on my pump and cant read anything off the old timer. My pump says Volts 230/115, and amps 8.0/16.0. I will be passing by lowes tom. so hopefully I can figure this out. What kind of timer do I need. Never was good with electrical.
    24' Round Above ground 13,500 gallons
    1.5 HP pump.
    Vinyl Liner
    150sqft Cartridge Filter
    Bottom Drain
    38,540
    Re: Pump Timer
    Quote Originally Posted by jamull2852
    That makes giving advice a bit scary
    First you have to figure out if the pump is wired for 115V or 230V (all we know now is that it could be either) ... post a pic of the wires in the timer maybe?
    You will need to get the correct timer for your voltage setup.
    Apr 2011
    Lynchburg VA
    393
    Re: Pump Timer
    Lowe's sells a timer made my Intermatic that will work for you. I have an outdoor timer that I have had for years and it's still going strong. I think I paid about $70 for it.
    http://www.lowes.com/ProductDisplay?par ... &cId=PDIO1
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Re: Pump Timer
    BadOleRoss, that timer will only work if the pump is setup for 240 volts. We don't what voltage the pump is, so it may not work. There is a very similar model that works for 120 volt pumps, but the first step is to figure out the voltage.
    Re: Pump Timer
    Dont worry I wont be touching any wires, my brother is an electrican but is busy remodeling his bathroom. So im trying to get everything ready so he can just come put it on and be done with it. Im trying to get in touch with the previous pool owner to see if its 110 or 220. Ill be back when I hear from him. Thanks.
    1.5 HP pump.
    Vinyl Liner
    Bottom Drain
    38,540
    Re: Pump Timer
    What are the wire colors running to the pump? Knowing just that we can be pretty sure which one it is ... assuming some crazy electrician didn't install the pump.
    OR.
    What type of breaker is the pump on? ... assuming the pump has a separate breaker.
    Re: Pump Timer
    Yes it does have its own breaker but Im at work right now and wont be home for another 8 hours. What kind of breaker will determine one or the other?
    1.5 HP pump.
    Vinyl Liner
    Bottom Drain
    38,540
    Re: Pump Timer
    You have to be sure that the breaker ONLY supplies the pump and not a subpanel at the pad.
    A 230V breaker is double the width of a 115V breaker.
    Re: Pump Timer
    Ok the previous owner just text me this. 110 from gfci breaker in garage all the way to the pump area. Hope this helps
    1.5 HP pump.
    Vinyl Liner
    Bottom Drain
    38,540
    Re: Pump Timer
    Intermatic T101 is the basic mechanical 120V timer.
    Lowes lists them on the website for $42 (indoor) or $53 (for the outdoor enclosure)
    Re: Pump Timer
    ok thanks alot jblizzle. Ill prolly go buy one tom. and try to get my brother over their to hook it up. Thanks again. I will report back tom. to let everyone know if it worked.
    1.5 HP pump.
    Vinyl Liner
    Bottom Drain
    Apr 2012
    Bonner Springs, Kansas
    109
    Re: Pump Timer
    Not sure if you bought one already, but I just installed this one today, does both 220 and 110 and works like a champ.
    http://www.amazon.com/gp/product/B001QF ... 01_s00_i02
    16'x32' -> 3' shallow, 8' deep ~22,000 gallon igp - Vinyl Liner.
    Sand Filter: Jacuzzi 225l-7 Sand Filter - 250lbs
    Pump: Hayward Max-Flo XL 1hp
    SWG: CircuPool RJ+ 60
    Water Source: Home Tap water (TA:230, CH:220)
