Thread: How to Properly Test CYA
    Dec 2009
    Virginia Beach, VA
    130
    I'm having some issues testing CYA with my new TF-100 test kit (first time using). Am I looking for the dot to completely disappear (i.e. no trace of a dot no matter how faint) or am I looking for the dot to change to a lighter shade of gray?
    My other test results are:
    Salt - 2430
    FC - 4.5
    CC - 0.5
    TC - 5.0
    TA - 130
    CH - 150
    CYA - ~23 if you wait until you can't see any trace of the dot
    30,000 Gallon Inground, Vinyl Liner
    DE Filter & Pentair IC40 SWG
    Pentair Legend Platinum w/ PB4 Booster
    Pentair Kreepy Krawler Prowler Robot
    38,303
    Re: How to Properly Test CYA
    Dec 2009
    Virginia Beach, VA
    130
    Thanks - I figured detailed directions were on here, just didn't quite know where to look.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,014
    Bright light is essential. I bought a bottle of the standard solution to check myself, and I'm right on if it's full sunlight and I only hold the tube with my thumb and one finger. Yes, even shading it with all your fingers will make it read different. Plus I take several readings; same solution, just pour it back in the mixing bottle, give it a shake, and repeat.
