Thread: Tested my fill water out of curiosity
    Jul 2011
    Henderson, NV
    24
    After all the work I've been putting in trying to "master" this pool thing I thought I'd test my fill water and see what the numbers were.
    Tested from the spigot where my Anti-Siphon is for the autofill
    FC: .5
    PH: >8.0
    TA: 140
    CH: 240
    Do these numbers seem about right? Living in southern nevada and dealing with the desert I know to expect CH issues and have been dealing with them. How does everything else measure up?
    Example of the fun CH battles.
    When we first bought the house last June
    And after lots of elbow grease
    Henderson,NV
    15x30 IG plaster; 18,500 gallons; Pentair 420 cartridge filter, WhisperFlo 2.5 HP SF 1.30;
    Autofill from tap water
    38,267
    Re: Tested my fill water out of curiosity
    Nice work on the tile ... what did you use?
    Fill water seems better than some. Biggest issue is the high pH and slightly high TA which will likely result in having to add acid to the pool as it refills.
    Jul 2011
    Las Vegas, NV
    37
    Yep, that's in line with my test results for good ol' Southern Nevada water, too, except for the pH. My test showed it was more or less neutral. I seem to recall the TA was a bit lower too, but not by much.
    My current CH in the pool is around 1060. As long as I keep a close eye on the other levels, I can maintain an acceptable CSI.
    33k in-ground plaster pool and spa / Goldline T-15 SWG w/ Aqualogic controller / RS2000 Hayward pump / Pentair Clean & Clear Plus 420 sq. ft. cartridge filter
    Jul 2011
    Henderson, NV
    24
    On the tile I used the toilet bowl pumice stones. Just enough grit without being too strong so it didn't scratch and lot's of time and elbow grease. Took around 3 days with my wife and I both working on it. Then after the bulk was off I mixed a heavy duty spray bottle with about 15% MA 85% water and went over it again. Sprayed 4-6 tiles at a time and scrubbed with a pumice again, then rinse from the hose. Then wiped them all down with a cloth which cleared up the residual streaks when it dried.
    When we moved in last June I tested the water and I think the PH was 7.8ish, definately higher now for some reason. I don't recall what the CH was then. The pool CH was at 1075 when I first started testing and I drained about 20% and refilled over the last two weeks which brought it down to 825. A little better at least. Pool was built in '06 and given the scale and CH readings I don't think the water had ever been changed
    Henderson,NV
