Thread: Self-aligning union
    Self-aligning union
    There is a type of union that is "self-aligning".
    Instead of the union mating surfaces being flat and parallel, there is a ball and socket type joint with an o-ring that allows for some axial misalignment.
    My previous owner had the pump (Superpump) and filter replaced and there is one of these self-aligning unions at the pump suction to account for the sloppy install in making up to the original skimmer and main drain 3-way. I think in my case they were asking it to do too much as I have always had problems with air leaks. I just dismantled, cleaned, lubed and reassembled to try to stop the air leak and now it's worse. I will be doing some replumbing myself.
    I haven't found much detail online. Hayward has an assembly for a different type of installation that comes with an elbow. I do know that the "hand nut"(?) part is much wider than a regular union.
    20,000 gal IG vinyl, built by Champion 1980. Hayward Superpump w/ 1 HP motor, Hayward S200 sand filter. TFP and inline chlorinator (for vacations).
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Self-aligning union
    I got a lot hits when I googled hayward self aligning union. Most hits were not right angle ones and they did have the wide nut.
